Grease Question
Old Feb 7, 2004 | 12:28 AM
Bronco2Nic's Avatar
Bronco2Nic
Question Grease Question
I'm finally putting my engine ('85 2.8L V6) back together and i'm wondering which lubricant would be better to use. I dont want to buy any new stuff so I have two to choose from. there is
A) White, Lithium based grease
or
B) Black, Oil based, Bearing grease.
that you for any help
Old Feb 7, 2004 | 02:03 AM
Boss_358's Avatar
Boss_358
The white lithium would work better of the two. Its closer to engine assembly lube. Although it may be the same.
Old Feb 13, 2004 | 03:11 PM
BigCrzyRdNeck's Avatar
BigCrzyRdNeck
Just buy engine assembly lube you can get it at oriellys.
Old Feb 13, 2004 | 03:19 PM
fastpakr's Avatar
fastpakr
I agree, with a newly rebuilt motor it would be unwise not to spend a couple of dollars on a tube of assembly lube.
