help
Old Feb 6, 2004 | 11:50 PM
repou's Avatar
repou
Question help
I have a 97 exped. The other day when i went to start it it didnt idle up it just sat there and ran at about 500rpms and would try to cut off when u hit the gas. Any suggestions? Also the other night the check engine light came on and now if you try to give it a lot of gas when in gear it gets a bad shake but it revs fine in neutural.
Old Feb 7, 2004 | 12:24 AM
tsdrallyer's Avatar
tsdrallyer
Check, clean or replace IAC valve and hoses. Clean MAF sensor. IF that doesn't fix it, get the code read at a parts store or the dealers.
