dodge tranny
Old Feb 6, 2004 | 10:50 PM
durk's Avatar
durk
dodge tranny
i have the transmission off of a dodge 318 and was wondering if it would bolt up to my 360. the c6 i have is on it's last leg and i need a temp. replacment so it can be rebuilt. i have heard that some dodge and ford transmissions will swap so i was just wondering. like i said it is off of a 318 and it is a 3 speed auto. i would be thankful for any help.
Old Feb 6, 2004 | 10:54 PM
Ratsmoker's Avatar
Ratsmoker
Welcome to FTE!!
I know of no dodge trannies that will bolt up to a ford engine but I do know it won't bolt to an FE. You will have to get the C6 rebuilt. They are very cheap to have rebuilt. $600 should get you a complete job and thats removal and install.
Old Feb 6, 2004 | 11:07 PM
durk's Avatar
durk
thanks for the help. i guess i'll just have to park the old truck for a week or two to have it rebuilt. or i could just buy on of those street fighter trans from summit. have you heard anything about them.
Old Feb 6, 2004 | 11:10 PM
Ratsmoker's Avatar
Ratsmoker
Yes I have and for some reason its not good news. There are a couple sites you might want to check out and see what they have to offer.
www.broaderperformance.com
www.transmissioncenter.net
Broaderperformace is probably going to give you the best bang for the buck. His stock trannies are way better than stock. That is all he does is C4s and C6s.
Old Feb 7, 2004 | 10:27 AM
davidoldfordfan's Avatar
davidoldfordfan
I guess I must be a bit behind the times as there is a beautiful 79 Crewcab for sale about a mile from me that someone has spent a ton of money on.
It is advertised with a DODGE transmission conversion????
I had not heard of it before but something must be up
Old Feb 7, 2004 | 10:52 AM
Ratsmoker's Avatar
Ratsmoker
It might be a 460 with a 727 Torqueflight behind it. They didn't put FE s in trucks in 79. I know you can run a turbo 400 behind an FE but I don't see why you would wanna do that.
Old Feb 7, 2004 | 12:24 PM
fordman428's Avatar
fordman428
i dont see why in the world you would put a dodge tranny in a ford to begin with, around my area dodges are going to the shop to get the tranny rebuilt, you dont see many fords dropping there tranny.
Old Feb 8, 2004 | 08:37 AM
4WD67F250's Avatar
4WD67F250
the "Dodge swap" he is refering to is most likely the NV4500 5 speed manual tranny. its very spendy but a good swap if you like manuals.
Old Feb 8, 2004 | 08:38 AM
bob arrington's Avatar
bob arrington
just out off couriosity, will a chebby bolt to a ford trans?thanks bob
Old Feb 8, 2004 | 08:46 AM
4WD67F250's Avatar
4WD67F250
no, not without a adapter. if there even is one. who would replace a C6 with a chevy tranny anyway, well maybe a 700r4
edit... sorry Bob, I just re read that last post of yours... I think I need my morning coffee!
good question, I know they put ford four speeds behind chebbies in racing all the time, dont know about autos though.
Old Feb 8, 2004 | 10:17 AM
durk's Avatar
durk
sorry to keep this subject going, but how would you put a turbo 400 behind an FE? does it need an adapter or will it just bolt up? sorry for all the questions. i don't know alot about engines but my dad is an all out chevy guy and he has a few turbo 350 and 400's in his garage. the reason i need a transmission so bad is that this truck is my daily driver and i don't want to have to start driving my 69 to work. but thanks for all the help you all have given me so far.
Old Feb 8, 2004 | 10:31 AM
Ratsmoker's Avatar
Ratsmoker
The turbo 400 swap does require an adapter. The C6 is said to be stronger thn any trans out there with the exception of the 2 speed powerglide.
Old Feb 8, 2004 | 10:36 AM
gtex's Avatar
gtex
I understand the NV4500 to be an OD manual. That's why it's appealing. 5th gear is something shy of 1:1, probably in the .75:1 range. This helps the old FEs with gas mileage.
Old Feb 8, 2004 | 09:03 PM
bamabanshee's Avatar
bamabanshee
yes the nv4500 i think would be a perfect fit for any old FE, it has a good low first gear to creep around in, (trailer pulling, offroading) and it has a GOOD overdrive so you can cruise comfortably at a good speed with out having to turn 3400 RPM.
i seriously considered doing the swap, but the tranny itself is gonna set you back 14-15 hundred, if you are lucky you can find one CHEAP. they have them out there for $1000 or so, but they want cores, so your still gonna have to pay. so you take your 1500 + 600-700 for an adapter kit from advanced adapters. and you get all your clutch stuff and linkage fixed up good, your looking at a wad of money and a good bit of time.
if your like me and your only 22 or so, and you plan on keeping and taking care of the truck it is probibly worth it in the long run, especially if that is what you really want, but i just cant justify spending the beans on it right now
Old Feb 8, 2004 | 10:42 PM
4WD67F250's Avatar
4WD67F250
banshee....
I hear you there! it will take a good while to regain the loss in cost of the swap to justify it at this time. I too am a young fella and money is tight anyway you put it when its going to cost 2k for a tranny. although it would be nice to have.
Durk... if you're still following this, my honest opinion (take it or leave it) is it will cost more and take longer to convert your dodge auto to fit your ford than it will to just have your C6 rebuilt.
but thats just my .02 cents.
