A different question about drums...
Old Feb 6, 2004 | 04:57 PM
BassGuy's Avatar
BassGuy
I'm wondering about rear drum to disk conversions. Would it require a huge undertaking to switch my rears to disk brakes? Is there any reason I should not do this?
Old Feb 6, 2004 | 05:11 PM
brianjwilson's Avatar
brianjwilson
I see no reason not to do it, I would much rather have discs back there than drums. Stainless Steel brakes makes a rear disc brake conversion, but it's a little pricey. You can find it at http://www.stainlesssteelbrakes.com/...nger&year=1998 (you might need to cut and past)
I would assume that you retain the ABS, anyone know?
Old Feb 7, 2004 | 07:51 PM
Dealford's Avatar
Dealford
The rear ABS is controlled by the VSS in the diff I believe.
Old Feb 8, 2004 | 03:17 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
You will want to check to see if you will need a different proportioning valve. I've seen proportioning valves that can be manually adjusted; my hunch is that you'll be needing one of these.
