Sponsored by: Kumho
brake problems
Old Feb 6, 2004 | 02:38 PM
highboy1975's Avatar
highboy1975
brake problems
im having problems with my breaks in my truck, and i cant figure out what the problm is. a few months ago, i went to stand on the brakes to stop guickly, and something gae in the pedal. since then, i hae had very minimal brakes. i put a new master cylinder on today and it still does the same thing for the most part. now, the brake pedal wil go almost to the floor, then seem to catch near the bottom. when the truck is shut off, i can pump up the breaks and get some pressure, but i can still push to the floor. any ideas would be appreaciated,
thanks,
john
Old Feb 6, 2004 | 05:12 PM
trwatson's Avatar
trwatson
check to see if you blew any lines in the front and in tthe back check the wheel cylinders if they blew, when you installed the master cylinder did you bench bleed it before you put it on? Did you bleed all brake lines front and back? Please don't get offended by the questions. It's hard to tell how mechanicaly inclined someone is.
Old Feb 7, 2004 | 02:52 PM
highboy1975
o i know, i completely understand. i bench bled the cylinder, and put it on, now im in the process of bleeding the brakes out. i've had people tell me different things on this. when i crack the bleeder, i only get a trickle, i'm under the impression that i should get a steady flow, im told that it sounds like i have alotta air in the lines. im not trying to go to a garage and pay out the wazoo for a break job that i'm able to do myself
john
Old Feb 9, 2004 | 08:00 PM
highboy1975
ok, ive bled my brakes completely, replaced the master, and still theres nothing. any help would be appreciated, im lost here
CollinsCD
26
Dec 27, 2013 02:10 PM
CopenGrizz01
13
Feb 24, 2012 07:48 AM
addybeer
Jan 24, 2012 07:42 PM
fromm
1978 - 1996 Big Bronco
30
Jul 3, 2009 07:31 PM
jon1
Bronco II
Jun 25, 2008 01:59 PM
