Need Help with Drum Removal.
Old 02-06-2004, 01:01 PM
XLT O_R Ranger's Avatar
XLT O_R Ranger
XLT O_R Ranger is offline
Question Need Help with Drum Removal.
I'll start from the beginning:
I have a 2001 XLT Off Road Ranger.
I knew I needed shoes on the back but pushed them as far as I could since I hate doing drum brakes.
Here's the kicker, my girlfriend drove it and used the emer brake that has never been used. It seized on. I drove the truck for a while not knowing that the emer brake was semi on. Until I had the window open one day at a stop light and smelt brakes. Sure enough it was mine.
I have since disconnected the emer brake line and I can move it and hear the parts moving inside the drum. Yet still the driverside drum heats up big time to the point that after 5 or 10 km you can hardly touch it.
It get's better, I cannot remove the drum and the adjuster seems to be stuck or seized.
Any tricks on how to remove the drum??
Thanks, Drew.
Old 02-06-2004, 01:55 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
CowboyBilly9Mile is offline
Sometimes the shoes wear into the drums a bit and it becomes necessessary to back off the self adjuster. Perhaps you can get to the threaded portion of the self adjuster after removing the rubber plug (I do assume it has one) and hit it with some WD-40. Sometimes beating on the drum with a rubber mallet will force the ridge in the drum over the brake shoe and you can get the drum off that way.
Old 02-06-2004, 03:15 PM
Ken00's Avatar
Ken00
Ken00 is offline
Be very careful spraying wd40 in the drum, you don't want to get any on the drum/shoes unless your going to clean/replace them.
Old 02-06-2004, 04:43 PM
V10man's Avatar
V10man
V10man is offline
Grab a small flashlight and a thin screwdriver and a adjuster tool( a bigger scewdriver will work) Try and line yourself up with the hole and shine the light in there. You will need to use the small screwdriver to push the adjuster arm off the star wheel. Then use the bigger screwdriver to back off the adjuster.
Old 03-02-2004, 11:53 PM
usedcrab's Avatar
usedcrab
usedcrab is offline
Alright, i have a 99 3.0 ranger, and one night i put on my E brake and the next day it was locked up, back right wheel, it wouldn't budge, so i jacked the car up one day, took the wheel off, and tryed pulling the drum off, nothing, it was stuck, so my father and we beat on the drum with a hammer while pulling on it, "since they're very very strong".
we used screw drivers to help pry it off after it was knocked loose with the hammer. It turns out that it had rusted together, so i sanded down the inside of the drum and lubricated the E-brake mechanism on both wheels and it hasn't had a problem since
hopefully that will help you out, and if it is attack that thing with a hammer
Ryan
Old 03-03-2004, 08:31 AM
77redf250's Avatar
77redf250
77redf250 is offline
if the e-brake cables are stuck i'd just cut(cable cutters work well) them off right before the drum and replace them when doing the shoes. you might have weak return springs too i usually buy a spring kit when doing a brake job since they only cost about $15.
Old 05-10-2004, 02:34 PM
scorp508's Avatar
scorp508
scorp508 is offline
Talking
Ended up having to cut the back left drum off with an airpowered Die Grinder from the Girlfriend's '99 yesterday. The right side adjusting screw broke in 1/2 earlier in the day demanding a brake job be done. When we tried to get the left drum off to do that side it would NOT come off. We backed the adjuster off as far as possible and the e-brake was off and no matter what the shoes would not move inward enough to get the drum off. Hammer, screwdrivers, nothing. Had to cut it. Oh well whast another $35 to have nice new drums on each side, lol.
Bakerr
1999 to 2016 Super Duty
04-02-2016 08:46 PM
Floggit
04-04-2015 05:17 AM
markd3682
04-03-2005 11:30 PM
cigarxtc
03-21-2005 04:54 PM
jor
06-29-2002 03:14 PM
Quick Reply: Need Help with Drum Removal.
