General Automotive Discussion
Focus help
Old Feb 6, 2004 | 10:29 AM
rabidranger's Avatar
rabidranger
Focus help
Not sure if this belongs here, moderators please move if so....
My fiance's 2001 Ford Focus has a blinker issue. I know the blinker fluid isn't low so that can't be the prob,
but the blinker won't turn off after a turn. You can turn the wheel lock to lock and the blinker stays on, both directions. I can do a motor rebuild and a gear swap no sweat, but messin with the column just scares me. Any ideas?
Old Feb 6, 2004 | 11:35 AM
Mil1ion's Avatar
Mil1ion
The cancelling cam is broken.
Old Feb 6, 2004 | 11:39 AM
parks911's Avatar
parks911
Re: Focus help
Did you use the manufatoer suggested grade of blinker fluid?
Actually, it is what Mil1ion had said.
Old Feb 6, 2004 | 11:56 AM
rabidranger
Should I try to fix it myself, or bite the $100 warranty deposit and take it in?
Old Feb 6, 2004 | 12:23 PM
cjben's Avatar
cjben
not sure about a focus, but I have seen some cars that it would be well worth the $100 to have someone else do it
Old Feb 6, 2004 | 12:48 PM
amsnss's Avatar
amsnss
From my understanding, no one in their right mind would dare try ripping apart a newer vehicles steering column for any make or model vehicle. Apparently there are a few "specialized" tools one must have to get through all of the little pivot points or something like that. I think $100 would be fine with me to get it to the dealer and let them deal with it.
Just my $.02 though
Old Feb 8, 2004 | 05:27 AM
LilBlackCoupe's Avatar
LilBlackCoupe
Spend the $100
Try and find some other things wrong while you're at it. Get as much done as you can for that $100
Old Feb 8, 2004 | 07:27 AM
bosshoss's Avatar
bosshoss
Unless you have a repair book, that tells you about the switch and air bag things you might be better off with the dealer. Buy a book and look at what it will take to repair the cam cancelling part. You might have to spend more on tools, books than the $100 dealer cost and risk damageing the air bag. Good luck
Old Feb 9, 2004 | 05:51 AM
rabidranger
Thanks guys. Think I will wait till something else goes wrong and kill 2 birds with one c-note. The power steering pump is already making noises so I am sure I won't have to wait long. Man... Ford trucks are tough as nails, but thier cars leave A LOT to be desired....
Old Feb 9, 2004 | 06:07 AM
bigric's Avatar
bigric
Yes, there's nothing like a controlled explosion in your face to get your attention and make you wish you'd spent the $100 (is my distaste for airbags showing?)...
