pistons
Old Feb 6, 2004 | 06:33 AM
RichardMaerz69's Avatar
RichardMaerz69
pistons
I did some more reading and found that the moified piston pins are a bit bigger and a bit longer can tghe w conecting rods be machined to fit the pins or will this weaken the rod to much.
Old Feb 6, 2004 | 02:04 PM
90f150moneypit's Avatar
90f150moneypit
Yes, they should be fine. Have a machine shop fit them for best results.
Old Feb 6, 2004 | 07:19 PM
RichardMaerz69
so the m pistons will fit with a little bit of work on the piston pins,but will the height differance screw me up from piston to spark plug clearance.If this does work what can I expect.
