Dual tanks
Old Feb 6, 2004 | 12:14 AM
tinman57's Avatar
tinman57
Dual tanks
Hi all, I have 2 trucks- a 96 F150 and a 92 F250. Both have dual tanks and both bave stopped registering on the front tank. Both run fine out of both tanks but when pulling out of the rear tanks both trucks return fuel into the front tanks.If the front tanks are full the fuel just pushes out on the ground. The local mechanic told me that it is bad pressure regulators.Just don't sound right to me.
Old Feb 6, 2004 | 12:59 AM
EPNCSU2006's Avatar
EPNCSU2006
There is a recall about this problem. The check valves in the in-tank sending units can become faulty and allow cross flow between tanks.
Old Feb 6, 2004 | 09:09 AM
jessfactor's Avatar
jessfactor
i always start on my front tank. when that is done i go to the rear. when that is done i go back to the front and use the fuel that was returned to the front (about 1/4 tank for me). then i fill up. is there anything that can break by not addressing this? i wasn't aware that it was a problem.
Old Feb 6, 2004 | 07:05 PM
EPNCSU2006's Avatar
EPNCSU2006
I don't think you can do any harm, but I honestly don't know for sure. The worst thing I can think would happen would be that fuel overflows from the front tank.
Old Feb 6, 2004 | 08:44 PM
jessfactor's Avatar
jessfactor
thats why i use the front tank first. sometimes trying to fix something that really wasn't bothering you can cause more problems to arise.
Old Feb 7, 2004 | 12:26 AM
tinman57's Avatar
tinman57
While that may be true,if I'm going to drop the tanks and make repairs on the sending units,I may as well fix it right if possible.
