no fuel
Old Feb 5, 2004 | 10:58 PM
shawnDOOKIE's Avatar
shawnDOOKIE
Exclamation no fuel
i kehi everyone. i keep losing power to my fuel pump on my 1989 f150 302 efi. then a fusible link burned out . enetria swth was supposedly replaced, new fuel pump supposedly, new tank, but before the link burned out, it would ride for a minute, sputter then die, but it ran fin in idle while parked.
Old Feb 13, 2004 | 10:15 PM
markfullen's Avatar
markfullen
i had a simmiler problem and found it to be the tank switching valve.
everything acted like a pump but it would allow enough air in to stall truck. it idled great but as soon as i started to go it would stall, just a thought. it would run down highway fine, does it do it on both tanks
Old Feb 16, 2004 | 09:12 AM
77redf250's Avatar
77redf250
check the wires going to the tank it sounds like the power wire is shorting out it might be pinched against the frame from the replacement. if there isn't a short you might have a bad pump
