Sponsored by: Real Truck
Where to find code
Old Apr 15, 2002 | 06:14 PM
GreenMachine's Avatar
GreenMachine
Where to find code
Old Apr 16, 2002 | 01:05 PM
TexasTechsan's Avatar
TexasTechsan
Where to find code
Okay guys, I have looked on the door jamb and there a ton of numbers, but none of seem to be the one I want, I am looking for a 3 letter 1 number group, but can't seem to find on that is not part part of some larger number sequence. BTW, it is a 2000 f250 4X4 (if it makes a difference)
Old Apr 16, 2002 | 01:45 PM
abendx's Avatar
abendx
Where to find code
on my 2002 it was up on the drivers door by the hinges.
Old Apr 16, 2002 | 03:59 PM
GreenMachine
Where to find code
My 2001 is on the driver's door, up by the hinges, as said earlier.
It is a cheapo paper sticker about 1.25"x1.25"
Mine is already puckered up and will probably fall off in the next 12 months.
Old Apr 17, 2002 | 02:45 PM
slammer's Avatar
slammer
Where to find code
I have a 2000 SD and mine in the drivers side door jamb by the hinges. Its a white sticker with black numbers (mine happened to be CPY2). It kind of looks out of place there and, before i decided to chip it, almost tore it off and threw it away.
If that sticker is gone, there is one on the ECM, located inside the kick panel on the drivers side. Just pull the plastic push pin and slide it out from under the door plate. Then there is a black plastic cover that holds the ECM in there, there are 2 bolts that hold them in, take them off... then comes the part.... go under the hood and reach behind, and below, the brake vacuum "thingy". there will be a 10mm bolt you gotta unscrew, dont worry about dropping it cuz it wont come out. Once that 10mm bolt spins freely,
go back into the cab and pull the ecm out. It will have the code on it.
I dont explain things too well but this entire operation takes less than 10 minutes.... once you do it 1 time.
If you need more help, post it, I'll help. I just finished the entire chip installation process and got very familiar with the do's and the of it all.
slammer
