Sponsored by: Auxito
O2 sensors getting lazy?
Old Feb 5, 2004 | 04:29 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Question O2 sensors getting lazy?
Is it possible that O2 sensors get lazy? Meaning,right before they go bad. My gas mileage has dropped almost 6 mpg in the last two weeks and I was told to replace my two upstream sensors.
Old Feb 5, 2004 | 08:18 PM
bosshoss's Avatar
bosshoss
Yes i have seen them get slow to respond or lazy. Not long after the light of Doom comes on.
Old Feb 5, 2004 | 10:33 PM
BlueOvalFitter
AAGGGHHHHH..........Not the light of DOOM!
Old Feb 7, 2004 | 09:13 AM
bosshoss's Avatar
bosshoss
You will have four sensors, two up stream and two downstream. The ones on the left side (drivers side) are bank #2, and the (passanger side) are bank #1 The sensors will also be called sensor #1 or Sensor #2. Sensor #1 is close to the engine. Sensor #2 is near the converters. This is the same for both banks. I use a 7/8 box wrench a lot of times to change them out. The #1 sensor on bank #1 is a little tough to do. I have found that a long flat screwdriver pressed on the lock tab will work good to unplug the old sensor from the harness. Have the truck worm also helps, but watch that you dont get burned. The new sensor will come with antisieze on the threads dont get that on the new sensor. Not to bad to do
Old Feb 7, 2004 | 01:56 PM
LxMan1's Avatar
LxMan1
The rear ones rarely need replaced. All they do is tell the PCM that the cat converters are working properly. They do not effect drivability.
I would replace the front two (closest to the engine). They are recommended to be changed every 60,000 miles due to carbon build up over time makes it hard for them to properly read the mixture.
Jimmy
Old Feb 9, 2004 | 10:21 AM
Mr J's Avatar
Mr J
I replaced mine last night. I was getting a misfire or "roughness" at about 1400rpm and now its gone. I replaced all four with the bosch ones @ about 55 each. That's 220 for 4 sensors. Better do something for my milage after an expense like that. Not to mention my burned, skinned knuckles. So much fun!
Old Feb 9, 2004 | 04:13 PM
jvangel's Avatar
jvangel
MRJ
How tough was it to replace the passenger side close to the engine o2 sensor. Did you remove the inner wheel well? I need to replace mine also.
Old Feb 9, 2004 | 06:13 PM
Bob Ayers's Avatar
Bob Ayers
Theoretically, with OBD2, if they get slow (lazy) they will throw a CEL:
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
Old Feb 9, 2004 | 06:57 PM
Mr J's Avatar
Mr J
i did remove the wheel, but I am not sure it was necessary. If you are real patient you can get an open end 7/8 up between the heat sheild and the pipe. With a little light and some tolerance for pain, you should be able to get it out.
robert_l_ross
Dec 28, 2015 10:30 AM
the real big daddy
Oct 26, 2015 11:15 AM
wulfman
Nov 12, 2014 11:36 AM
Wanted
1983 - 2012 Ranger & B-Series
Mar 6, 2005 07:57 PM
jcmac
Apr 9, 2001 11:14 AM
