1999 Navigator Headrest Removal - Please Help.
Old Feb 5, 2004 | 12:44 PM
TurboKuake's Avatar
TurboKuake
I already searched the forum and only found one thread on this with no replies.
I was wondering the secret to releasing the headrest from the seat. I'm sure many people on here know how these come off and I would really appreciate it if someone would share it with me.
Sorry if it sounds like a stupid or dumb question, but i'd rather ask before I go yanking and tugging and breaking stuff apart.
Any help would be appreciated. Thank You.
Old Feb 5, 2004 | 02:18 PM
the4by4freek's Avatar
the4by4freek
Not really sure on this but most I have seen have a little button on the very top of the seat back. It is located at the base of the headrest post on the trim that goes around the post. Push it in and pull up at the same time. It should come right out!
Old Feb 5, 2004 | 05:38 PM
TurboKuake's Avatar
TurboKuake
Nope, No button
There are little pin holes in them though and i tried putting a paperclip in it to see if it was a release, but it didn't seem to do anything. Anyone else know??
thanks
Old Feb 6, 2004 | 12:12 PM
TurboKuake's Avatar
TurboKuake
I can't believe that there is no one on this board that knows this. No one has installed a/v systems here? What's the deal?
Old Feb 6, 2004 | 01:54 PM
the4by4freek
just give it a good yank! it should eventually come out! Sorry I couldn't help!
Old May 12, 2012 | 09:29 AM
dbarlow39's Avatar
dbarlow39
Pin Holes
On my 1999 Navigator there are pin holes on top of the seat where the head rest go through and in to the seat. I used a #00 phillips head screw driver but anything more substantial than a paper clip can be used to push the retaining ring located inside the pin hole. I found you had to push pretty good to move it. Once you push through the pin hole with your 00 screw drive you can lift the rod up but it will not come totally out until you do the same thing to the other side.
You'll need to keep upward pressure on the head rest so that the first rod does not slip back down and reconnect while you are trying to get the second rod to release. As you keep upward pressure on the head rest while pushing in the 2nd pin hole both sides should slip out for you.
Old May 12, 2012 | 12:14 PM
alwaysfords41's Avatar
alwaysfords41
I hope in the eight years since he asked the question it has already been resolved.
Old May 20, 2022 | 06:06 PM
MJR Reyz's Avatar
MJR Reyz
1st Gear
Amazing
I hope the original person asking the question saw the answer. Helped me in 2022… 18 years later 👌
Detstar8022
Mar 31, 2017 06:35 PM
Aaron285
Aug 7, 2016 07:02 AM
Mick83
Modular V10 (6.8l)
Dec 27, 2015 03:13 PM
Northroadak
2009 - 2014 F150
16
May 2, 2013 09:58 AM
CrewCabLongbox
Feb 15, 2012 07:10 AM
