Sponsored by: Auxito
4WD Problems, not engaging
Old Feb 5, 2004 | 11:10 AM
medic130's Avatar
medic130
Angry 4WD Problems, not engaging
A lot of good a 4wd truck does in 2 foot of snow when the front axle won't engage. Or when it does it disangages on its own. Still under warranty, but the dealer wants to keep it for a few days. HA, there's two foot of snow on the ground!!! I can see the vacuum operated front axle engaging but I want to know if there is another actuator on the transfer case.
Old Feb 5, 2004 | 11:34 AM
LxMan1's Avatar
LxMan1
It has an electric motor that shift the transfer case for you instead of pulling a lever.
Does the 4x4 light flash or anything?
Old Feb 8, 2004 | 07:33 AM
MasterT's Avatar
MasterT
What year is the truck.
If Its a 03 like mine could be the shift fork. Two little fingers could break off. My truck been in the shop for over a week now, seems they can't get the part. It's backordered.
Old Feb 8, 2004 | 03:56 PM
5.4AZ4X4's Avatar
5.4AZ4X4
I may have the same problem in my 01. when I turn the switch it will engage the front driveshaft but its not turning the front tires so there is something else that isnt engaging.
Old Feb 8, 2004 | 05:50 PM
RDsF150's Avatar
RDsF150
Hey guys great site and my first post. I have a 99 XLT 4.6 Triton V8. My question is when I engage my 4W and turn the wheel at slow speeds it acts like it is rubbing something. I am not much of a mechanic and not sure how to check it. The 4W light is on and no problem driving straight. It is fine in 2W. Thanks
Old Feb 9, 2004 | 09:21 AM
grizz5675's Avatar
grizz5675
rdsf150
rds all 4x4s when they are engaged will feel like something is rubbing when your making sharper turns ,with a 4x4 engaged you should try to round out your turns, so dont worry but try not to turn sharp.
Old Feb 9, 2004 | 09:44 AM
LxMan1's Avatar
LxMan1
Never engage the 4x4 and try to turn on dry pavement. It binds up the drivetrain and can start breaking things!!!
Jimmy
Old Feb 9, 2004 | 10:23 AM
CONTRiC's Avatar
CONTRiC
<http://www.google.ca/search?q=cache:...hl=en&ie=UTF-8>
That is a google cached link of a conversation about 4hi on pavement. Good read for this topic :P Not specifically for fords though, nonetheless interesting to read.
