v6 to v10 conversion
Alright guys, I am tired of trying to make my 2002 4.2l go fast, so here it is. I go to the best performance shop in my town, ask if he can supercharge or turbocharge my truck. He goes out looks at my truck and says w/the money that I'm going to spend turbo or supercharging it you might as well drop a new motor in. I say ok that sucks. He says a buddy of mine has a 2002 6.8l V10 motor he is trying to get rid of. He only wants $1500 dollars for the complete engine(this truck only has 7,000 miles on the engine). I know I'll have to get a new tranny. Can anyone help or give me some tips so I can make this swap happen(what all am I going to have to do). Also if anyone else knows a cheaper or smarter way of putting a different engine like a 4.6 or 5.4 in let me know. PLEASE help, i am going to do something to get this truck moving w/over 300hp w/in the next 2months, I just need some direction and skilled advice.
thanks,
Brad
thanks,
Brad
Charles6,
After some thought, I decided I did something I dont agree with. I always think, if you are going to do something, do it right. So here goes. This is what I think about upgrading to a 4.6L. So hear me out:
First, lets look at what we have. You have an '02 4.2l that yields 202HP at the flywheel. You are interested in a 4.6L engine, and that same year, it yields 231HP at the flywheel. Lets assume you have the standard tranny. It has been said that a manual will lose you 20% to the rear wheel. Others say it depends on the actual tranny, and this is what I believe. We have the 5 speed manual, which leads to 161, or 152 rwhp. Lets use 155 as a median. The 4.6L with that same setup, equates to either 185, or 182 RWHP. Lets use 182, since its lower, and to be more fair to gains/losses.
At this point, youve successfully upgraded your truck 27HP. Is the extra cash worth 27HP? Moving on. Lets say you want to get a hot engine. So you figure out how to fit in a Cobra 4.6L. You produce 390HP with 8 pounds of boost, and 6k RPMs. The price tag, on the other hand, is a shade under $6,000. Plus install, gaskets, etc. For $6K, dont you think you could upgrade your 4.2L to be nearly (maybe not exactly) on that level? I promise you, with the vortech SC, intercooled, you will see more than 100 RWHP gain. 100 HP is what the non-i/c'ed kit gets you. Period. Then, with plus or minus $2200, you can add on exhaust, headers, NOS, 90mm MAF, 42lbs injectors, AND a custom chip.
So basically, if you are willing to spend that kind of cash in order to "go fast"? Not counting the SC kit, Ive spent over 3200 on my truck. And I dont regret a single thing about it. I have taken a couple chevy 1500's, mainly cause Im a better shifter, but still. Im not trying to tell you how to build your truck. It is entirely up to you. Nor am I trying to make you think that your best route is to by the kit I have up for sale. I am just the guy that tries to break down things logically. Which now leads me to say this: These figures were purely hypothetical, except what I pulled from spec sheets, and did the math on my pc calc. If I am a little off on my exact science, I appologize.
Keep in mind, this is talking about a 4.6/5.4L that may require more than just the base cost. As far as the V10 is concerned, they are outfitted in f250s and bigger. I think you would run into a fitment issue with the f150. It would be more headache than anything. Is there a guarantee about the working order of the engine? 1500 is damn cheap for any engine...aside for maybe a chebby one
Just thoughts to ponder my friend. Welcome to FTE, by the way, I dont think Ive seen you around before.
I agree completely. Engine swaps from the 4.2 to a 4.6-5.4-or the 6.8 will require many parts besides the engine. I think you will find the overall cost will be surprisingly expensive. The best bang for the buck is a supercharger. The SC would take you up to the 300 HP range for $3,100 plus a day or so of your time for the install. If you decide you want more HP later you just add an intercooler, increase boost, and get your chip re-burnt. Another option is to swap out the stock heads and cam for performance items, throw on a set of headers, and have your intake ported (or replace it also). This will also get you in the 300 HP range fairly easily.
Well guys thanks for the info. I already have intake, exhaust, and a tbs. It's just that the truck looks so much faster than it is. Horizon you said w/a supercharger I'll be pushing 300hp @the rear wheels w/out an intercooler. Correct? That is perfect! Where are you located, and will the supercharger hender the life span of the vehicle. I'm about to go off to college, and it has to be reliable. Also when if I do get a supercharger what other things "accessories" am I going to have to get to make it run correctly, such as chip headers anything extra that I'll need. By the way I looked up a bunch of specs for the V10 and 11mpg and the headache putting the thing in isn't worth it. The thing weighs too much and I'll have to redo everything from the flywheel back.
Thanks guys so much for your opinions and I'm looking forward to talking again.
Thanks again,
Brad
Thanks again,
Brad
By the way Horizon now I am definately interested in a s/c. If you would e-mail me the price. I think its against the forum guidelines to do it here. mpetershome@valuelinx.net.
thanks,
Brad
thanks,
Brad
Brad,
Youve blocked your email address in your profile. You can either email me via my profile, get on AIM and IM richcranium510, or go to this link and do the other two options:
http://www.got-pressure.com/yabbse/i...;threadid=1578
I will give you all the details then. Contact me
