What's the differance?
Old Feb 4, 2004 | 10:26 PM
duback66's Avatar
duback66
What is the differance betwwen a 13-56 and 13-45 transfer case and will either one work on a 89 f-150 with a four speed that is two wheel drive? I am wanting to convert to four wheel drive. Thanks
Old Feb 5, 2004 | 06:45 PM
Lobuck76's Avatar
Lobuck76
bw1356 replaced 1345 in late 80's or early 90's. It is said that the 1356 has a magnesium case, stronger than aluminum 1345 case. They look about the same to me. Both bolt up the same. Some 1356 tc's had slip yoke rear output.
Not sure about mating to 2wd tranny, I would check the search for that info. Ron
