transfer case
Old Feb 4, 2004 | 09:20 PM
the_ottogz's Avatar
the_ottogz
transfer case
today i was able to put my 92 exploder into 4x4, the motor worked, but when i looked to see if the front shaft was spinning it wasn't, could this be that damn motor showing a wrong positon, or could this be something more serious. its gotr 110k miles on it and the tranny runs good. i will replace fluids and take apart the shift motor totally. Has this happened to anyone else??
Old Feb 5, 2004 | 12:00 AM
phonebem's Avatar
phonebem
Try pulling the motor off and seeing if it moves when you push the button. If it doesn't we have your problem, if it does you have problems... I once accidentally switched my '95 Explorer into 4Low while it was moving and unfortunately it gutted the case.
Old Feb 5, 2004 | 02:34 PM
the_ottogz's Avatar
the_ottogz
about how much does a transfer case cost at a junk yard, and if i do go ahead and get one, should i just go for the manuel and make it fit my automatic. I am still going to fix the motor this week along with an oil change, i will look at the transfer case to see if it has any shrapnel in it, is thier anything else i should do to see if it is in one peice, how long does it take to swap a transfer case
Old Feb 5, 2004 | 09:51 PM
phonebem's Avatar
phonebem
I have no idea how much one cost at a salvage yard. I'll assume the motor worked, I'd advise having it checked-out first it may just be something simple like a linkage being jammed (keep your fingers crossed). One things for sure, going from an auto to a manual Tcase would be the most expensive option.
Old Feb 5, 2004 | 09:55 PM
daerhldgs2's Avatar
daerhldgs2
sometimes you have to try a few times before it engages ,especially if you don't use it a lot.If it's the motor I think you can adapt a shift arm quite easily.
Somerowl
18
Nov 27, 2017 10:40 AM
3KP
Mar 4, 2017 12:41 PM
JaniceDelp
Engine Swaps
Feb 24, 2017 07:33 PM
Jolly Roger Joe
65
Jan 22, 2017 06:30 PM
BigBlackF-250
Jun 19, 2015 02:21 PM
