93 f150 heater blower problem
Old Feb 4, 2004 | 07:28 PM
pursable's Avatar
pursable
My blower only works on high, I installed a new blower motor and still only works on high, any comment would be great thanks
Old Feb 4, 2004 | 07:37 PM
99 ranger bob's Avatar
99 ranger bob
check the ground on the switch and if all else fails replace the blower speed switch sometimes they fry inside
Old Feb 4, 2004 | 08:26 PM
ATC_250SX's Avatar
ATC_250SX
there is a resistor, i do belive its mounted right beside the blower motor in the engine compartment it has a plug with like 5 wires on it, thats more than likely your problem, it controlls speed by resisting power, i think thats where it is but as soon as you find it and remove it you can look at it and see if its blown, if it is one of the lilttle wires will be broken.
Old Feb 5, 2004 | 08:54 AM
larry derouin's Avatar
larry derouin
Definately the speed resistor. Seen more than enough of these on Fords, GM's and Chry's. to agree with ATC. Real easy fix. Plug and Pray! 2 screws on the blower housing (Fan air keeps it from overheating), pull out, install new one, plug in and go!
Larry
becida
Jul 26, 2015 08:06 PM
jdb1967
Jan 17, 2014 12:39 PM
Sickler1
Aug 14, 2011 07:36 PM
nickh
Feb 1, 2009 07:43 PM
BIZZEEROG
1997 - 2003 F150
Dec 21, 2005 02:20 PM
