98 Explorer Weird Wurring noise
Old Feb 4, 2004 | 06:56 PM
carollo3916's Avatar
carollo3916
Question 98 Explorer Weird Wurring noise
Wife's 98 explorer w/ auto 4x4, 4x4 hi, 4x4 low switched at dash. Although the trany and 4x4 functions appear to be working fine ---
-When reducing load on engine ( going down incline) something kicks on in the transmission or transfer case that "sounds like" it was just down shifted. It sounds similar to the rpm's reving up then slowing down except actual rpm's remain constant. The noise will stop if the gas is applied or the vehicle stops. It's a loud wurring noise, almost like a motor disengaging itself all the sudden then spinning out of control until it slows down.
Any ideas on what could be the problem, cost to fix??-- actuator motor, sensors, flywheel??? I'm justing trying to get educated before I take it in to a dealer and get taken to the cleaners.
Thanks for your imput.
Old Feb 4, 2004 | 11:01 PM
willys4x473's Avatar
willys4x473
I know you said it sounds like it's coming from down below, but the noise you are describing sounds like the fan clutch engaging.
I've had these go out on me before, and if they stick in the on position-it makes a pretty loud noise-reminesant of a turbo, and it is really hard to tell where it is coming from in the cab. But usaually they seem to stick and get unstuck before they freeze up or come apart.It will also eat up lots of power and gas mileage will suffer, or if it sticks in the off position it could cause it to overheat.
Good Luck
Old Feb 17, 2004 | 09:07 AM
DTP's Avatar
DTP
loud wuring noise
I have the same noise, but only when the engine is cold,
I always thought it was the transmission.
Have you been able to get the problem fixed?
My vehicle is 2000 Ford Explorer.
Any other ideas.
dtp
Old Mar 4, 2004 | 01:51 AM
flytripper's Avatar
flytripper
check this out
Hey try this recent thread. We discussed this in detail. I think from the limited info you provided that this may be your problem as well....
.https://www.ford-trucks.com/forums/s...hreadid=186448
let us know
Old Mar 9, 2004 | 04:13 PM
DTP's Avatar
DTP
Thanks Flytripper,
I tried the 4 wheel thing and it didn't help.
I did notice today the loud whur sound was there even
when the engine was warm. It comes and goes.
dtp
