Sponsored by: Kumho
Biggest Tires?
Old Feb 4, 2004 | 05:14 PM
jpjshy13's Avatar
jpjshy13
Biggest Tires?
Hey sorry for posting such a stupid subject, but i was just wondering what is the biggest tire size that i could put on my 1993 Ford F-150.. This is without a lift, so im not sure what would really fit for bigger tires.! If anyone can help.. that would be great.. thanks in advance.
Old Feb 4, 2004 | 07:04 PM
864x2mudder's Avatar
864x2mudder
32x11.50s
Old Feb 4, 2004 | 10:53 PM
92 f150300six's Avatar
92 f150300six
33/14/15
Old Feb 5, 2004 | 08:13 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Is this a 4x4 or a 2wd? I would think 31x10.50's would fit iether. Maybe up to 33's on a 4wd, but that might be pushing it on a 1/2-ton. I don't have any problems fitting 33's on mine but mine is a 1-ton 4x4; rides a little higher.
Old Feb 6, 2004 | 07:37 AM
72f100's Avatar
72f100
33's will fit, just don't go too wide with the rim. A 33x12.50 is a bit too wide for the factory rims so you will need new rims to make it work properly. My brother had a 1990 Bronco w/ 33x 12.50 on 15x10" wheels and they fit OK. They would rub the plastic inner fender a little when you turned and if you were stupid and got air w/ it they will just touch the fender lip (my brother found this out the hard way )
Old Feb 6, 2004 | 08:37 AM
jpjshy13's Avatar
jpjshy13
Thank you very much for your replys.. Myne is a 2 wheel drive and i was just looking to put something bigger than the tires that i already have on there.. Right now im about to put 31X10.50-15 General Grabber MT's.. But thank you for your help.. Much appreciated!
