electrical guage probs
Old Feb 4, 2004 | 04:13 PM
cowboy2u01's Avatar
cowboy2u01
well here it goes, i got gauges going everywhere... tach jumping up to 2000 at idle (improper) temp guage, volt also jump ... any ideas... havent put in on a scope yet ...so any initial help would be great as to where to start.... just put another engine in it as well... from a ford explorer 4.0... this started prior to the engine swap...
Old Feb 5, 2004 | 03:40 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
It sounds like a short in the instrument cluster. Sorry I can't be of more help.
Old Feb 5, 2004 | 04:23 PM
87 XLT's Avatar
87 XLT
I read somewhere that a bad connection in the engine to body ground strap can cause this.
Old Feb 5, 2004 | 10:43 PM
hreed's Avatar
hreed
I agree. Sounds like a bad ground.
Old Feb 6, 2004 | 06:06 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I'd check the noted ground and try to find where the cluster makes ground contact with the chassis. Often it's a wire with a lug that is screwed to the firewall or steering column structure under the dash somewhere. If you can get your hands on a wiring diagram it might help you locate this ground.
