Aerostar Ford Aerostar
Spark plugs 3.0
Old Feb 4, 2004 | 10:12 AM
Beaned's Avatar
Beaned
Cool Spark plugs 3.0
I have a '97 shorty 3.0 74,000 miles. The previous owner had the spark plugs changed but I don't know when. Any guide lines for regular spark plug changes and what brand of plugs?
Great site,
Thanks,
Beaned
Old Feb 4, 2004 | 10:14 AM
Bob Ayers's Avatar
Bob Ayers
Motorcraft double, or fine wire platinums.....
Old Feb 4, 2004 | 07:07 PM
ha38349's Avatar
ha38349
60,000 miles is the recommend change interval. Use Platinum plugs (I have used Bosch) Changing the plugs is such a pain that you don't want to do it very often.
Old Feb 4, 2004 | 07:31 PM
chucknc's Avatar
chucknc
Changing plugs are 6 levels of hell, with #6 being the worst. Definitely use the best you can buy, you'll be glad you did.
Old Feb 5, 2004 | 07:38 PM
Beaned's Avatar
Beaned
Thanks for all the replies. I'm gearing up to change the plugs. I read in somebody's manual that you change at 100,000 miles. Then some have said 60,000. This seems more resonable.
Beaned
Old Feb 6, 2004 | 07:59 PM
ha38349's Avatar
ha38349
Having done this last summer I have a few tips. For reference right side means looking forward (passenger side), left side is drivers side.
Get a spark plug wire puller, I wasted a lot of time just trying to get the wires off.
Start on the right side, jack up the wheel and remove. Right rear plug is best attacked from below. Middle and front plug attack through the wheel well.
Remove left side tire, attack rear plug through the wheel well. It is a very tight fit. Put the socket on the plug first then fit the handle. Middle and front left side can be attacked from in front through the hood.
Pick a nice day when you have lots of time (and beer).
Old Feb 6, 2004 | 08:37 PM
Beaned's Avatar
Beaned
Thanks Ha38349,
These details help alot.
Beaned
Old Feb 6, 2004 | 10:30 PM
eehoepp's Avatar
eehoepp
Good tips from "ha38349".
I found it useful to use a deep offset box end wrench that fits the outside hex on the spark plug socket (3/4" IIRC). It really helps on the rear plugs on each side. This type of wrench has the box end dropped about 1.5" below the level of the handle - it looks like a "Z" from the side. The 1.5" depth is needed so the handle clears the exhaust manifold. I picked one up at the local cheapo-tool house for less than 10 bucks & save it for just this occasion.
Cheers,
Eric
Old Feb 7, 2004 | 01:02 AM
JTHill24's Avatar
JTHill24
Also you can remove the Air Filter box. Just 3 nuts holding it on. and you can then reach the Spark Plugs on the passenger side
(1,2,3) from the front of the van.
With the Box out you can reach in between the Fan, Alt, & Air Cond.
Old Feb 8, 2004 | 08:07 PM
Beaned's Avatar
Beaned
Thanks all for responding. I'm printing out all this info.
Beaned
Old Feb 9, 2004 | 12:09 AM
scott9050's Avatar
scott9050
I rebuilt the engine on my Mustang but I will never change the plugs on my van again. Next time I will pay Pep boys the $80 they charge to do the tuneup.
Old Feb 9, 2004 | 06:44 PM
ha38349's Avatar
ha38349
Better ask to see the old plugs if you pay someone When I did mine at 100,000 after paying someone at 60,000 I found only 4 of the 6 had been replaced. The two worst ones to get at were the originals.
Old Feb 10, 2004 | 11:04 AM
Beaned's Avatar
Beaned
Well, ha38349,
Thats a real bummer! I'll do mine myself. With all the info on this thread, I feel good about doing it.
Beaned
Old Feb 22, 2004 | 11:37 AM
eastvanmikee's Avatar
eastvanmikee
the easiest and fastest way to change the plugs is to remove the top half of the intake manifold, only 6 bolts and the throttle cable( no gasket required).Now you can reach right down the side of the motor and reach the rear plugs..45 minutes max.....
Old Feb 22, 2004 | 03:11 PM
Beaned's Avatar
Beaned
Thanks for the reply,
That sounds like it would simplify things.
Beaned
