More Firewall leaks detected !!
Old Feb 4, 2004 | 01:11 AM
bodinejcs's Avatar
bodinejcs
Hello Again guys ,
After finding the firewall leak over #3 cop ( I stated #7 but ment #3) , I have found a few more leaks . They are at each end of the wiper cowl cover where it swoops down . After runnin the garden hose really good , I have determined that there are leaks at each end of the firewall . If you look straight down from there you will see a big loom of wires and a plug that gets pretty wet from the leakage . On all my fords in the past , ya kinda want to keep the moisture away from the wiring if all possible and with all these leaks and electonics inder the hood , its a wonder they run as well as they do . Anyway , after futhur investigation on the cover , there is a 1/4 " foam gasket that adheres to the firewall and sends all the water out to the fenders . Trouble is the adhesive is terrible and just would let the water leak past . Take a little black weatherstrip adhesive and glue that puppy down . You can wad up a rag and place it between the little fender tab and the cover to hold it down until the adhesive dries . I pretty much have it leak free after extensive testing . Not sure what the wire looms are but keeping them dry seems like a good idea over the long haul . hope this helps some of ya , Comin soon , I gonna dig into the flickering odometer next , theres a bad solder in there somewhere , I will post my findings . Thanks All !!
Old Feb 4, 2004 | 01:18 AM
pounder90's Avatar
pounder90
Re: More Firewall leaks detected !!
[i] Comin soon , I gonna dig into the flickering odometer next , theres a bad solder in there somewhere [/B]
You mean this bad solder joint?
https://www.ford-trucks.com/forums/s...hreadid=196821
Old Feb 4, 2004 | 01:45 AM
bodinejcs's Avatar
bodinejcs
Awesome , thanks for pointing that out to me , I knew that it was that easy , I ve done a few Bmw ones , can't wait to dig in and fix it . Thanks Friend !
Old Feb 4, 2004 | 02:04 AM
pounder90's Avatar
pounder90
You're welcome. It doesn't surprise me that you've seen this on BMWs. I owned a 528 and it was almost like the designers didn't want the electrical connections to have continuity.
