Sponsored by: Real Truck
Steering Stabilizer?
Old Apr 22, 2002 | 05:13 PM
Waxy's Avatar
Waxy
Old Apr 24, 2002 | 12:07 AM
wafflerr's Avatar
wafflerr
Post Steering Stabilizer?
I have a 2002 F-250 CC, PSD, SWB, 4x4. The feedback from the steering wheel is lousy. I was thinking that it is caused by the Firestone Steeltex ATs and the wimpy steering stabilizer.
After taking a look at the steering, I COULDN'T FIND the steering stabilizer. Did Ford stop putting them on the 2002s?
I'm also interested in opinions about who makes the best steering stabilizer.
Thanks!
Old Apr 24, 2002 | 12:49 AM
LW555's Avatar
LW555
What do you mean by poor feedback? Is it slow to return to center? I would take it to the dealer to have it checked out. The steering should be pretty responsive with the stock tires. A steering stabilizer will dampen everything out... so if it's slow to return, it will be even slower with one.
Ford only puts the stabilizer on trucks with the "off-road" package.
The best direct replacement stabilizer in my opinion is made by Fox, but it's about $140.
Old Apr 24, 2002 | 12:58 AM
slammer's Avatar
slammer
I have a 2000 SD and my truck wandered. I put a Rancho steering stabilizer on it and it helped quite a bit...BUT... the real source of the problem was the lower ***** joints.. they came "ungreaseable" so my dealer warrantied it and put greaseable ball joints on it and my problem was solved
IMHO, I would use Rancho....cost.... $112.00 ( because you have to order the mounting kit as well)
slammer
Old Apr 24, 2002 | 05:10 AM
Yeti's Avatar
Yeti
LW555, is correct a stabilizer will just "mask" any feedback.
As far as the best brand to go with.. matter of opinion, rancho, skyjacker, etc are all good names. I have a double skyjacker that I paid $98 bucks for through National tire and wheel, it comes with the brackets. However, I would not recomend a double for stock tires, as far as Im concerned, it's overkill on my truck with 35's, the wheel does not return to center without help.
Old Apr 24, 2002 | 07:42 AM
wafflerr's Avatar
wafflerr
>with one.
Any harshness in the road during turns (above 20 or so mph) really upset the steering wheel.
>package.
That really bums me out... I've always had one on my trucks - will have to retrofit one.
Sounds great - Thanks for all of your help!
Rob
