Condenser
Old Feb 3, 2004 | 11:52 PM
Mark VIII's Avatar
Mark VIII
Condenser
Hello everyone I noticed on my 78 F250 that there is a condenser mounted to the coil. Mine is missing the wire that comes out of it. How important is this condenser and were does the wire go?
Old Feb 4, 2004 | 02:02 AM
Torque1st's Avatar
Torque1st
Posting Legend
That was probably some aftermarket radio noise suppression device. You can remove it.
Old Feb 4, 2004 | 09:08 AM
KJKozak2's Avatar
KJKozak2
Torque is correct. It is a noise suppression condensor to keep engine noise off the radio. There should be one on the coil and another coming off the voltage regulator.
I don't think it's aftermarket though. My wiring diagrams for my 78 F150 in the Haynes manual show them in both places. I didn't have any on mine when I bought it, but I added them. Without them, I couldn't even use a battery powered hand held CB radio in the truck the static was so bad.
I got mine at a swap meet for a buck a piece. Couldn't find them anywhere else, but you might try the HELP section of your local auto parts store.
Kevin K.
Old Feb 4, 2004 | 12:08 PM
LxMan1's Avatar
LxMan1
It is factory. It also helps keep voltage spikes out of the ignition system!! I would put another one on there.
Jimmy
Old Feb 4, 2004 | 12:33 PM
Mark VIII's Avatar
Mark VIII
Condenser
Where does it hook up to?
Old Feb 4, 2004 | 06:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hmmmm, my truck doesn't have the one on the coil and my wiring diagram does not show it. I do have the one on the VR tho. My radio worked OK before it ate a tape and put itself in tape mode continuously.
Old Feb 4, 2004 | 10:08 PM
LxMan1's Avatar
LxMan1
It hooks to the extra red wire on the coil connector.
The side that does NOT say tach on the connector.
Old Feb 4, 2004 | 11:51 PM
Mark VIII's Avatar
Mark VIII
Thank You for your help!
Old Feb 5, 2004 | 09:19 AM
KJKozak2's Avatar
KJKozak2
Torque,
It's possible that not all engines had the one on the coil. I'll check my diagrams again. I put one on the coil of my 460 because there wasn't one there, but there was one on my 351.
K.
Old Feb 5, 2004 | 07:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
My wiring diagrams are not OEM and are very poor But then I could rewire one of these old beaters in my sleep. When I was a kid and working in a service station I used to make money on the side rewiring old farm trucks, adding turn signals, clearance lights, etc etc.
