Excursion Performance Question while towing
Old Feb 3, 2004 | 11:10 PM
snort's Avatar
snort
Excursion towing Question
I have a 2000 7.3 excursion. I will be pulling a 7000lb trailer about 2500 miles in total.
Is that too much weight?
If it's OK, when should I turn off the overdrive and when can I leave it on?
What RPM should I consider the limit for normal operations with the overdrive off?
Any info would be greatly appreciated as I am new to towing a trailer like this and I am new to the excursion.
Old Feb 9, 2004 | 08:59 PM
bigdieseldav's Avatar
bigdieseldav
Not just trying to boost your ego here but 7000lbs. to your excursion is nothing, and you will be fine in OD, just keep it 65-70 and your mileage should be fine as well. The only time i switch out of overdrive is on steep hills while pulling and that is just to keep my Exhaust Gas Temps down, and thats with about 12000lbs. you'll be fine!!
Old Feb 12, 2004 | 11:26 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I have to agree with bigdieseldav, 7000 pounds is nothing for the Excursion. The only time I would turn off OD is when it starts "hunting" for gears while going uphill. Otherwise leave it on and don't put your foot into it.
