Offroad & 4x4
100 Mile Retorque.
Old Feb 3, 2004 | 08:03 PM
natewoz's Avatar
natewoz
100 Mile Retorque.
I just finished installing my 2.5" lift today. The instructions say to retorque all the fasteners after 100 miles. Does anybody actually do this and is it really that crucial? It would be quite a bit of work, and some fasteners would be impossible to reach. Thank guys.
Old Feb 3, 2004 | 08:37 PM
rlh's Avatar
rlh
I'm sorry, I just can't help it though. If you don't mind your suspension coming apart at 75 mph . . . don't worry about it!
Old Feb 3, 2004 | 08:41 PM
85351ho's Avatar
85351ho
do it again at 500 too.....then just keep an eye on stuff
the u bolts are especially bad about loosening up
Old Feb 3, 2004 | 09:17 PM
natewoz's Avatar
natewoz
My origional post makes me look kinda stupid. I understand that making sure that everything is tight is important. Just wanted to know if everyone else did it. Also, I torqued all the 1/2" hardware to 90-100 ft lbs, what torques did you guys use?
Old Feb 3, 2004 | 10:36 PM
MustangGT221's Avatar
MustangGT221
Just follow the torque specs that are on the instruction sheets. It shouldn't be too bad to check the torque on the bolts, better safe than sorry.
Old Feb 3, 2004 | 10:48 PM
JeremyH's Avatar
JeremyH
I check most components after every wheeling trip.
Old Feb 3, 2004 | 11:48 PM
rlh's Avatar
rlh
We all have our moments. Its really a good question. The instructions should have listed the torque specs.
Old Feb 4, 2004 | 07:00 AM
teds74ford's Avatar
teds74ford
Over time, you may find that only the same ones are coming loose. I had this problem, and those got loctite.
Old Feb 4, 2004 | 08:36 AM
natewoz's Avatar
natewoz
Yea, the torque specs were 85-90 ft lbs. I used medium strength loctite on all the fasteners, and all the bolts have nylock nuts on them.
Old Feb 4, 2004 | 12:14 PM
Busa01's Avatar
Busa01
Ah, I have a question.
I just installed my lift kit. Fabtech 7.5" which replaces/lowers the two crossmembers in the front (2WD). The upper control arm came stock with a fixed, non adjustable spacer on it. The kit came with cam bolts that replace these non adjustable spacers, so that the wheels can be aligned properly.
I installed and torqued them to spec. Took the truck to Tires Plus for an alignment. They did a great job. After they aligned it and retorqued the cam bolts, I double checked the torque, then added a second bolt onto it and torqued it against the first bolt with loctite, to make sure it wouldn't slip.
However, every time I take the truck off road the cam bolts slide all the way in which makes the front tires cave inward. I'm afraid if I torque these cam bolts any more they might snap.
Any suggestions???
Thanks,
Tom
Old Feb 4, 2004 | 04:57 PM
natewoz's Avatar
natewoz
Well, I had a great day. I was doing my alignment, and the camber cam bolts that Tuff Country brags about were apsolute crap! The front bolt stripped out the d-hole in the round "washer". When I did the rear, I used a tranny jack to take some of the weight off of the bolt. Well, that pos ripped out it's hole too! I'm furious! Now I have to replace those bolts with some new ones, and then find thick fenderwashers to fit the rectangular area where the eccentric was supposed to go. Do you think I should weld them? Then I have to redo the alignment check, buy the correct bushings, and install them (which is not going to be fun at all!). I was very dissapointed in these eccentrics because the rest of the braketry was very well made. I think I'll give 'em a peice of my mind.
Old Feb 4, 2004 | 09:57 PM
rlh's Avatar
rlh
I'd contact them ASAP and ask them WTF. You shouldn't be able to do that with a torque wrench. Thats why I tend to lean towards Dick Cepek and Sky Jacker.
monte97z
Mar 17, 2012 07:09 AM
Confederate Diesel
Jan 2, 2011 12:11 PM
Brad Leroy
20
Feb 25, 2010 03:15 PM
jasond5150
2004 - 2008 F150
Jan 17, 2008 06:31 PM
