1978 - 1996 Big Bronco
some questions
Old Feb 3, 2004 | 07:34 PM
whoop09's Avatar
whoop09
Question some questions
For those of you who have had more experience than me, I have some questions. I am feeling a vibration when I give it a very small amount of gas or let off of the gas slowly. I only feel this when I am barely pushing on the gas or just starting to lightly. I am also feeling an extremely light ticking feeling when I am going slowly. The other thing is the steering wheel shakes around 60-70mph. I had it aligned and the tires balanced recently so I don't think that is that.
I know that is a lot of things, but something tells me they are related. Any advice on where to start would be great.
Old Feb 3, 2004 | 07:45 PM
BOJOFASO's Avatar
BOJOFASO
well lets start with the low speed vibration, check your trans fluid and make sure it is not burnt and that it is full.your high speed shake in the steering wheel may be that you have trown a wheel weight off and the tires are out of balance.
you did not say if all this just started to happen or if it has been a little at a time. if all this is at once you may have a bad u joint. are your hubs auto or manuel? if they are auto one of them may not be disengaging and if they are manuel mabe some one engaged it for you.
