No signal lights
Old Feb 3, 2004 | 04:19 PM
Alberta dave's Avatar
Alberta dave
No signal lights
My 86 F-250 has lost its signal lights. Hazards work, no blown fuses and I put in a new signal plug into the fuse panel. I am guessing that the problem may be in the steering column but before I tear it apart I need to know if I am missing something else. Any thoughts on where I should turn or is there a method of confirming the steering column switch is pooched without removing the steering wheel?
Old Feb 3, 2004 | 05:10 PM
77150's Avatar
77150
I have a 77 f-150 and when I got it, it had the same problem. I had to replace the switch in the steering colum.
