timing
Old Feb 2, 2004 | 09:42 PM
rancherman84's Avatar
rancherman84
timing
anybody besides spectramac advance thier timing.will you notice the difference?
Old Feb 2, 2004 | 10:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I advanced my 6.9 about 4 or 5 degrees. Yes it made a difference but, the 6.9 was set at 1.5 to 4.5 ATDC depending on the cetane value of the fuel you are using, where the 7.3 is 8.5 BTDC from the start.
More snow in the forcast......LMAO
Old Feb 4, 2004 | 09:45 AM
Spectramac's Avatar
Spectramac
It depends on where you timing is at now. I checked mine because it always sounded fairly quiet. I then noticed only 1 out of the 3 bolts were even tight on the pump. I went from 0 to 8+ degrees, so there was all kinds of difference. I had to keep lifting my foot on the highway cause I was going about 5-10 mph faster then normal.
