what do ya think
Old Feb 2, 2004 | 09:33 PM
rangersvt04's Avatar
rangersvt04
what do ya think
ok i just got my preformance products for my FORD mag in to day and i am wondering if i order a 1998 K&N fipk(for the 3.0L) will it work on my 96 3.0L? and allso thinking of ordering a bbk throttle boddie 66mm. has any one delt with this comapny before and do you think the fipk will work ??
Old Feb 3, 2004 | 06:46 AM
rangersvt04
bump
Old Feb 3, 2004 | 03:51 PM
Ken00's Avatar
Ken00
Try contacting our parts store, they may be able to answer your question and you might find a better price.
Old Feb 4, 2004 | 08:22 AM
rangersvt04
ive asked them before and i havent recived a reply yet but i will ask again
Old Feb 4, 2004 | 09:29 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
I think your 96 engine has an intake with an integral throttle body, so changing to a larger throttle body is not a bolt on option. The 96 has a conical air cleaner style and the 98 has a flat panel air cleaner. I would call K&N directly and ask them if their part will work on a 96.
Old Feb 4, 2004 | 03:50 PM
jt-stl's Avatar
jt-stl
K&N doesn't make a FIPK for the 93-97 3.0L. You have to use a universal cold air induction kit and get a conical K&N filter seperately. It's not difficult, you get the same results and it's cheaper than buying the K&N kit.
Old Feb 4, 2004 | 08:10 PM
Hank85713's Avatar
Hank85713
You can get a free flow aircleaner kit from Streetsmart design. I put one of theirs for a 97 on my 94 4.0, the big difference is that the 93-96 upper radiator hose sits higher than the 97 on. I had/have no problems with the install, and after I did the install then called them and told them what I found they started to list the older models. The kit was around $175 for a chrome tube, all the silicone joints, the adapter for the aircleaner (K&N) and a bracket to hold the MAF.
I dont have their URL to link to but do a search for the above and you will find them.
I also have a 2.5inch exhaust sytem from the Y pipe, a free flow cat, a magna flo muffler. The shop used just a standard bender but limited the amount and degree of bend in the system, keeping it fairly straight/flat.
You will need both intake and exhaust system to see any real improvement.
daner01
20
Nov 10, 2010 10:37 AM
mdjohnson
Nov 22, 2005 01:18 PM
Steve Butabi
Sep 8, 2004 08:24 AM
opcenter
Aug 15, 2004 01:01 PM
BigMattXXL
Jul 3, 2003 08:09 PM
