I was wondering if it is possible to chrome over the old school method of using lead as a body filler? Or would a chrome place use lead to fix something if you took it to be rechromed?
I've had several bent bumpers rechromed, including a 57 Bird rear. The plater repaired the bent metal before replating. The bumper, when returned, looked as good as new.
After the acid bath (also known as "stripping"), Large holes are fixed by welding. Some shops use a two part epoxy which is both conductive, and platable for filling pits.
