no dash lights
Old Feb 2, 2004 | 06:50 PM
MTZBoeger's Avatar
MTZBoeger
no dash lights
ford 1977 f-250 4x4 no dash lights or right side plinker light on panel.?
Old Feb 2, 2004 | 07:46 PM
Franklin2's Avatar
Franklin2
Check the fuse.
Twist the **** on the headlamp switch.
Pull the cluster out and check for voltage at the bulbs. If there is no voltage, then I would suspect your headlight switch dimmer unit is bad.
