Sponsored by: Auxito
Check engine light
Old Feb 2, 2004 | 03:37 PM
pvaughn's Avatar
pvaughn
Thumbs up Check engine light
Old Feb 2, 2004 | 03:42 PM
pvaughn's Avatar
pvaughn
can anyone give me any info on check engine light (egr. valve) on a 2001 F-150 supercrew?
Old Feb 2, 2004 | 04:31 PM
vicyuribry's Avatar
vicyuribry
Go to autozone and have it checked, they do it for free. and then you can go from there.
Old Feb 2, 2004 | 10:04 PM
fordborn's Avatar
fordborn
Make sure your gas tank cap is tight. If it is not tight it will cause the light to come on.
Old Feb 3, 2004 | 06:21 AM
cwfish's Avatar
cwfish
Just had a Check Engine light come on in my 1998 F-150 4.6L V8. Turned out to be the heater hose leaked onto the spark plug and filled the spark plug hole with coolant. Simple fix, tighten the clamp on the heater hose and clean the plug and wire. Might want to check it out if you haven't found your fix yet.
Old Feb 3, 2004 | 07:07 AM
Fordlover55's Avatar
Fordlover55
Still kicking!!
I have had the check engine light on for the last 6 months or more. The last time I took it to the dealer, they told me it was running rich on one bank and that Ford was supposed to do a tech article on how to fix it. Still nothing. Now my warrantee is gone and its going to cost me a mint to take it to a dealer..whom I now have no faith in. The next best dealer is in another town and I don't really want to walk home and wait for it...nor can I afford it right now.
Old Feb 3, 2004 | 05:21 PM
Lcashmer's Avatar
Lcashmer
I'm not a lawyer, but if you have a service order stating the condition existed and they were waiting on info from Ford, that particular problem is still in warranty. Anything that was identified while it was in warranty and not repaired due to the dealer or Ford is still covered. This is if you have done due dillegence in following up with them and it hasn't been a year or anything.
If you don't have it in writing, you'll have trouble making it stick. I used to work for a competitor. I'm sure Ford would love to know that a dealer is blaming lack of a tech article for not fixing something. You can appeal to Ford in cases like this.
Hope this is some help.
Old Feb 3, 2004 | 07:58 PM
ford-fanatic73's Avatar
ford-fanatic73
in bank 1 or bank 2 it the O2 sensors in my truck 97 f150 5.4 also clean the Mass airflow sensor with carb cleaner and check the pcv valve it is super cheap to replace $6
