Sponsored by: Real Truck
engine sound from 5.4
Old Apr 29, 2002 | 07:38 PM
dbugem's Avatar
dbugem
Hey guys, any one with a 5.4 have a high pitch sound when slowing down from say 65mph? My truck does it when getting off the xpressway and take my foot off the gas to slow down. Sounds kinda like turbo whine but I got a 5.4.
thanks,
dbugem
Old Apr 29, 2002 | 08:03 PM
redranger1's Avatar
redranger1
are you sure it isnt noise comming from yer tires bouncing off of the retaining wall? i know my truck does it especially on offramps and bridges. i dont think that the engine has anything to do with it.
-nathan
Old Apr 29, 2002 | 08:15 PM
dbugem's Avatar
dbugem
REDRANGER1
THANKS FOR THE SERIOUS ANSWER.
dbugem
Old Apr 29, 2002 | 09:01 PM
tex71's Avatar
tex71
I've had my 5.4 for two years now and never noticed any whine. I'll start listenin' and see if I hear it.
Old Apr 30, 2002 | 02:21 AM
Rockwell's Avatar
Rockwell
I dont think RedRanger1 was joking with you, tires can make some strange noises and because of the fact they are spinning they can also throw their voice so to speak.
Another thought, did you in any way modify your stock airbox, or replace it with an aftermarket setup? My airbox is modified and whenever i am slighlty on the fuel pedal i get a whistling noise just like it has a turbo, just like you describe. Someone on here had sugested it may be from the air rushing past the partialy open throttle body plate. Or, maybe you have a leak somewhere in your intake?
Old Apr 30, 2002 | 01:11 PM
doogen's Avatar
doogen
My engine has made that whistle sound on acceleration since it was new. I don't have a modified air box either. I am less concerned about the whistle noise as I am about how oily this engine gets. I had to wipe down the brake fluid res the other day so i could read it and I only have 17k on this 2001 engine. everyone else with the v-10 or v-8 getting oil mist blowing on everything in your engines???
Old Apr 30, 2002 | 02:07 PM
Big's Avatar
Big
I don't notice any tire whine on my truck. I have about 55k on my buggy now and still have the original Steeltexs on it. They are ready to be replaced but I have never noticed the noise.
As far as Redrangers comment, I think dude was serious. The noise from the tires could be bouncing off of concrete walls or even guardrails. I kinda took his post like you did at first and thought it was funny, but looked at it again after your post. He has a good point. I assume he is a he.
As far as oil in the engine bay, I too notice all that oil. I think I have a leak in the head or head gasket. I can't afford the head job right now (no jokes please!). I will get it looked at when business picks up a bit. Yeah, my PS reservoir is pretty messy.
Big
2000 F250 SD SC 5.4L Gasser 4.10s 4x4 L/S rearend Western 7'6" plow (hate it-have to have it)White with parchment cloth
Old Apr 30, 2002 | 02:40 PM
dbugem's Avatar
dbugem
ok guys, its definetly not tire noise because i can hear it when I take my foot off the gas pedal on the open road. I have not modified my airbox yet. I do have a K&N filter but the sound was the same before and after installation. When sitting in the truck sounds like it is coming from the middle to the passenger side of the engine compartment. The truck has had it from the first day and when under 50-55 mph its gone.
thanks, the mystery continues.
dbugem
Old Apr 30, 2002 | 03:30 PM
V10gunner's Avatar
V10gunner
>afford the head job right now (no jokes please)
Now why do you think we would joke about this?
-V10gunner
'00 SD F250 Super Cab XLT, 4X2, 142"WB, 6.8L V10, 4R100, 4.30LS, Camper Package, Dark Toreador Red over Silver, Line-X, Husky mud flaps, Snugtop Xtra Vision Cab-high shell, AutoMeter Tranny Temp Gauge, Banks Stinger and TransCommand
Old Apr 30, 2002 | 06:11 PM
Rockwell's Avatar
Rockwell
Yikes, sorry to hear about oil getting all over these engines, my 2001 5.4 is clean as could be at about 14K on the odometer, I hope it stays that way!
Old Apr 30, 2002 | 07:02 PM
4x4x4x4's Avatar
4x4x4x4
>its gone.
>dbugem
My V-10 has a bit of front axle whine when the hubs are locked and I let off of the gas.It is more pronounced in 4wd.Could the front or rear ring and pinion be your noise?Just a thought .
Old Apr 30, 2002 | 08:46 PM
redranger1's Avatar
redranger1
yes redranger1 was serious. i have noticed that when comming on and off of ramps that there is a whine noise that comes from the vehicle that bounces off the retaining wall. he didnt say that it was all of the time so i assumed it was just on ramps. guess that just prooves what assuming does.
and yes redranger1 is a he.
-nathan
Old Apr 30, 2002 | 10:18 PM
Monsta's Avatar
Monsta
Sit. Stay.
You should really check you intake system. Especially where it meets the throttle body.
A simple way to test for possible air leaks is to start the engine and spray WD-40 around the "joints" on the plastic intake snorkel & where the throttle body meets the manifold. If your idle changes, then you just found your leak. (A motorcycle troubleshooting tip)
I would also inspect all of your vacuum connections.
Another possible source, although remote, would be your alternator bearings.
A pulley could give off a whining sound. Hard to really comment on that since I've never heard your sound though...
Old Apr 30, 2002 | 11:03 PM
FortyFords's Avatar
FortyFords
Don't forget the thermostatic clutch fan hub being a source also.
Mine makes a whine since new ,more when it kicks in.
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old May 1, 2002 | 07:51 AM
dbugem's Avatar
dbugem
Thanks for all the ideas guys. I'll start checking them out.
P.S. Redranger1; Thanks, missread on your post, appreciate your help!
