Brake boost failure
Old Feb 2, 2004 | 12:50 PM
kmans777's Avatar
kmans777
Brake boost failure
Hi guys, just lost all power assist to the brakes on my 88 Ranger. The pedal is hard and the brakes operate just the way they do with the engine not running. I found some troubleshooting tips and tried them. Check for vacuum line blockage. None. Pinch off vacuum hose to booster and check for rpm increase. None. Listen for hissing from under dash when brakes applied with engine running. None. The engine rpm does increase by about 500 when I push on the brake pedal. This I don't recall as being normal. I was having some idling problems along with a fuel pressure regulator that was bad. After changing the FPR the truck wouldn't idle once warmed up. So as a temporary fix til I had time for further troubleshooting I bumped up the idle using the adjustment screw on the throttle body. I know this is not the way to do it, but needed the truck driveable for a few days. Could this have some effect ? Also went to this site: http://www.mightyap.com/Data/gb0802.pdf. Gave me enough doubt that I didn't run out and buy a new booster. Any help appreciated.
88 Ranger XLT 2.9L 4X4 5Spd
Old Feb 2, 2004 | 07:00 PM
Dealford's Avatar
Dealford
With the idle rpm increase when the brakes are applied, sounds like the diaphram in the booster is leaking. This could also explain why the truck doesn't idle very well.
Old Feb 3, 2004 | 06:17 PM
kmans777's Avatar
kmans777
Thanks Dealford, after some discussion with a friend, came to same conclusion. Changing the booster fixed the problem.
andrewscofield
Sep 11, 2019 10:55 AM
friction
Aug 7, 2013 06:53 PM
hairyboxnoogle
May 27, 2013 03:23 PM
78 Ford F150 460
13
May 18, 2013 01:45 PM
mrflip2
Jan 24, 2010 06:55 PM
