Which wires?
Old Feb 2, 2004 | 12:03 PM
buzalski's Avatar
buzalski
Unhappy Which wires?
I think I've got a bad IDM or injector wires on the left bank. I've got a code for and open circiut to the left bank and when I disconnected the harness to the IDM I can't seem to find which are the right ones to check. I read on a post, the the resistance should be 5k to each injector, but that didn't specify which wires. I didn't find any with 5k, so now I wondering if that was even correct. Does anyone know the correct diag procedure to determine if it is the Harness or the IDM that is faulty? I sure would like to get this figured out.
Thanks,
Dave
Old Feb 4, 2004 | 08:42 PM
cangim's Avatar
cangim
Connector that is on the valve cover, the two outer wires(Brown on left, yellow on right) on each end, are for the glow plugs. The four in the center go to the injector modules, in order with cyclinders. Looking fan back, closet pin, closet cylinder to you. Don't know what Ohms you are looking for though, good luck.
Mike
