I thought I was being real smart by ordering my new truck with the snow plow package to level the truck. It works well but when I put any kind of load in the back it rides nose high. Is there some way to lift the back end only an inch or two? This should compensate for most of what I haul.
My truck has the plow package ,too.I was wondering if you tried anything for your lift and, if so, how it worked.Thanks
What gvw springs do you have in the back ?
I have 8800lb gvw springs back there with 2"blocks,I also have the snowpkg) springs in the front
This thing doesn't sag at all when loaded
Just had 4 vermont casting stoves in the back they weigh 350/piece
It does ride stiff though
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
>I have a F250 4x4 02 sc
Ditto, absolutely no problems with sagging here even before my lift.
>my lift.
Yeti! you had a lift operation !
<https://www.ford-trucks.com/dcforum/Images/staun.gif>
not with rocks
If what I have read around here before is true,you could install a set of F-350 rear blocks and gain 2in.in the rear height.Don't know if your current u-bolts are long enough or need replaced .
