Bronco II Ford Bronco II
power door locks no go
Old Feb 1, 2004 | 08:40 PM
waywoos's Avatar
waywoos
when i hit my power door butto the passanger door doesnt lock.
what part is defective?
is it called the acctuator.
i hear it clicking but the button doesnt go down like drivers door.
thanks
Old Feb 1, 2004 | 09:29 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
Thats what its call but if you hear it clicking you may have another problem, make sure the linkage works smoothly.
Old Feb 1, 2004 | 10:04 PM
waywoos's Avatar
waywoos
oh ok
so white litium grease ok to use?
Old Feb 2, 2004 | 12:35 AM
pozner's Avatar
pozner
It would be, but you may need to lift the protective rubber cap and use something lighter to go down into the solenoid. Use lithium on all the linkages, though. You may need a flashlight to see inside the door shell.
Also, consider that a door wire may be breaking on the driver's side. See if the passenger switch works the same, or does it work better?
