Question about wiring brake controller.
Old Feb 1, 2004 | 08:29 PM
Sycostang67's Avatar
Sycostang67
Question Question about wiring brake controller.
I pirated the brake controller from my mothers truck, since my parents don't have a trailer to pull. All the wires were labeled, but one thing confused me. The battery wire went from the controller through the firewall, and then split under the hood, one side to the battery, and the other side followed the brake wire back the trailer plug....I think, it was wet outside and couldn't get under to look. Would this be for a charging system if you were pulling a camper? Also, the brake controller has 2 slide adjustments on the front, and then there is a wheel on the bottom towards the back of the controller, what could it be for? The brake controller is a Tekonsha 2030 Mark 12.
Old Feb 1, 2004 | 10:37 PM
blackhat620's Avatar
blackhat620
Sycostang67,
Here is a link to Tekonsha page. Scroll down to your model and click on the link and it will open a pdf file with the instructions.
www.tekonsha.com/faq.html
Old Feb 1, 2004 | 11:43 PM
SoCalDesertRider's Avatar
SoCalDesertRider
The slide control on the front is for applying the trailer brakes by hand, seperate from the tow vehicle brakes. The wheel is most likely for adjusting the strength of the braking being applied to the trailer. You are likely right about the power wire going to the rear of the vehicle being a charge wire for the trailer. It should be fused too.
Old Feb 2, 2004 | 03:19 AM
Sycostang67
thanks for the link, it helped a lot, now I need to dry weather to install this thing.
Linusthedog
All Things Towing
Jul 1, 2025 11:51 PM
EricNCSU1204
24
May 4, 2017 07:18 PM
ddavidv
Sep 28, 2014 01:53 PM
FordTrucksKickGM
All Things Towing
Jan 9, 2008 03:25 PM
dnroberts
All Things Towing
Mar 30, 2006 11:08 AM
