4X4 light flashing
Old Feb 1, 2004 | 02:33 PM
bru77's Avatar
bru77
4X4 light flashing
Having a problem with 99 f250-SD PSD 4x4 light flashes intermittently and I can here noise in front end. when I slow to stop I here a thump and feel it on the break pedal. Any ideas? Can I unhook the auto 4X4 switch?
Thanks
BC
Ps this dose not happen all the time Every 20 to 30 miles
Old Feb 1, 2004 | 04:00 PM
cwb's Avatar
cwb
Boy I have never heard of that one. Course, I am just the town idiot around here. I would sure be interested to find out what it is.
Old Feb 1, 2004 | 04:16 PM
bru77's Avatar
bru77
Thanks for the reply cwb i will post what i find out
BC
Old Feb 1, 2004 | 10:00 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The auto hubs are vacuum operated, and as far as I know are not connected to the dash light. The electronic shifter on the transfer case is probably the culprit, try cleaning out the connector, aslo check for loose/damaged wiring.
Old Feb 3, 2004 | 08:08 PM
bru77's Avatar
bru77
Talking Thanks cookie88
Thanks cookie88
Found dirt & loose connector on upper 6 pin connection. Cleaned & replaced so far so good thanks again
BC
Old Feb 3, 2004 | 08:21 PM
cookie88's Avatar
cookie88
FTE Emeritus
Re: Thanks cookie88
Originally posted by bru77
Thanks cookie88
BC
No problem. Back in my USAF days we were taught to troubleshoot using the K.I.S.S method (Keep It Simple Stupid). That always works for me since I'm about as sharp as the leading edge of a bowling ball.
Old Feb 3, 2004 | 09:06 PM
cwb's Avatar
cwb
Don't feel bad, I am as sharp as the trailing edge.
