stering 10.5 bolt pattern
Old Feb 1, 2004 | 01:44 PM
fordbronco84's Avatar
fordbronco84
I heard that at some point ford went to a metric bolt pattern on the stering 10.5( and I would assume all axles) Does anybody know what year this happened. I found a 1993?? (burned)f350 with a sterling 10.5 rear axle 4:56/factory posi and rear disk brakes for $350.00. I just want to make sure the bolt pattern is the same as the dana 60 from a 1988 f350 I have will be the same.
Thanks,
1984 FS Bronco
in process of being an
f350 bronco
Old Feb 1, 2004 | 08:27 PM
Greywolf's Avatar
Greywolf
1998 or 1999 I heard, for the eight lugbolt pattern. 1997 for the five bolt lugbolt pattern. I smacked into that during the single to dually modification on my F250.
~Wolf
Old Feb 2, 2004 | 01:29 AM
Txquadhunter24's Avatar
Txquadhunter24
they changed in 98 with body style change
Old Feb 2, 2004 | 09:56 AM
fordbronco84
Thanks for all your help
Fordbronco84
Old Feb 2, 2004 | 10:04 AM
NoMo's Avatar
NoMo
Weren't all of the pre-1999 model Sterling axles 10.25" (not 10.5")?
Old Feb 2, 2004 | 10:40 AM
82F100SWB's Avatar
82F100SWB
Indeed, pre SuperDuty axles are 10.25", not 10.5, only real difference is the bolt pattern on the hub(there are metric 10.25's tho) and the ring gear itself
Old Feb 2, 2004 | 01:52 PM
fordbronco84
I found out that the truck is a 2001 f350. This would be the metric bolt pattern. I wonder if i could get flanges redilled to match the front dana 60 bolt pattern
Old Feb 3, 2004 | 07:01 AM
82F100SWB's Avatar
82F100SWB
You should be able to re-drill the hubs and rotors, or maybe just swap to older hubs and re-drill the rotors. At worst, you could just swap to the older drums...
Old Feb 3, 2004 | 11:48 AM
NoMo's Avatar
NoMo
If it's an '01, then the FACTORY gearing was 4.30 (or 4.10 or 3.73). If the axle truly has 4.56 gears, then it has been modified.
ptra2417
22
Nov 23, 2023 01:58 PM
mojavearcher
Jan 24, 2017 06:24 PM
ExploringNH
Feb 8, 2014 01:31 PM
steves_F350_460
Aug 11, 2010 02:38 PM
moosebrew
Jul 6, 2010 09:04 PM
