Sponsored by: Real Truck
Door opening problem
Old Feb 1, 2004 | 01:22 PM
pocobueno's Avatar
pocobueno
Question Door opening problem
One door on my F250 Crew Cab is distinctly harder to open than the rest. It's loke you have to shove it open (or pull hard, as the case my be) Anyone else with this same situation? Any ideas as to cause and fixes. I've looked it over and don't see anthing wrong.
poco
Old Feb 1, 2004 | 08:00 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I moved you over here, in hope of you getting a few more responses to your question.
Enjoy
Old Feb 1, 2004 | 08:24 PM
FortyFords's Avatar
FortyFords
Which door on the crew cab?
It may just be it needs a little lube in the hinge pin area .
or when the truck was assembled one of the hinges could have been misaligned when the guy torqued it down ,causing a bind
First I would chk all my gaps in the door area for even amount of space all along the doors .
Has it been this way since new or been getting worse as time goes on.
Rich
Old Feb 2, 2004 | 08:34 AM
pocobueno's Avatar
pocobueno
Rich
Hi Rich,
THank you for your reply.
Is is the rear drivers-side door and has been that way since I bought it. I thought maybe it just needed some time to "break in" but I'm at 4000 miles and no different yet. I'll get some WD 40 and see if it helps.
poco
Old Feb 2, 2004 | 01:08 PM
FortyFords's Avatar
FortyFords
Remember wd-40 is not a lubricant its a penetrant
use that first then try some silcone spray
Also the hinge itself could have been assembled to tight.
Did you chk all your gaps along the door?
Also take it to the dreaded dealer ,your under warranty yet.
Rich
Old Feb 2, 2004 | 02:59 PM
pocobueno's Avatar
pocobueno
Rich
Thanks again.
The dealer... oh my... only if they promise not to reflash my truck
Thanks!
poco
pin8246
Jan 6, 2013 09:52 PM
kupaa
Oct 19, 2010 03:05 AM
sthrnforddriver
Sep 21, 2010 10:42 AM
cookie2
Escape & Escape Hybrid
Jul 30, 2007 03:27 PM
haslipe
Aerostar
Sep 10, 2006 01:41 PM
