DS window regulator
Old Feb 1, 2004 | 07:15 AM
Terrie's Avatar
Terrie
DS window regulator
Do any of you have any idea how or a site that can show me pictures, to help me change the regulator on my 97 EXPY. I know the rivits have to come off the old regulator. Other than that I am clueless.
Terrie
Old Feb 1, 2004 | 10:05 PM
buzzard's Avatar
buzzard
Removal
1. Remove the front door window glass.
2. Remove the window regulator electric drive
3. Note: Use care not to enlarge the sheet metal holes in the door inner panel.
Remove the center pins from the rivets, using a drift. Using a 1/4-inch diameter drill, drill out the rivets attaching the window regulator lower bracket to the inner panel.
4. Remove the nuts retaining the window regulator upper bracket to the door inner panel.
5. Remove the window regulator.
Installation
1. Follow the removal procedure in reverse order.
* Use the Heavy Duty Riveter to install the rivets
Good Luck.
