Sponsored by: Auxito
late oil change
Old Jan 31, 2004 | 07:16 PM
NDrum2005's Avatar
NDrum2005
late oil change
Will not changing the oil every 3k miles cause any problems with the truck (see sig.) My dad always waits till every 6-10k before changing it. Will this cause any problems down the road?
Old Jan 31, 2004 | 07:21 PM
LxMan1's Avatar
LxMan1
I believe the manual calls for every 5000 miles.
I would go much more than that . Oil breaks down over time and will start to sludge in the engine.
Old Jan 31, 2004 | 11:17 PM
DeckedoutF150's Avatar
DeckedoutF150
i would also use a synthetic oil in it
Old Feb 1, 2004 | 12:24 AM
PaulC's Avatar
PaulC
You risk endangering the warranty coverage on the engine if you don't change the oil per their recommendations and a lubrication-related failure occurs.
Old Feb 1, 2004 | 10:25 AM
AegisSailor's Avatar
AegisSailor
Is risking your engine even a little bit worth the $25.00 you save by not getting an oil change? If you change the oil yourself it costs even less.
You engine is a complex, high RPM machine. It needs good, clean lubrication.
