Throttlebody and Injectors needing cleaned
Old Jan 31, 2004 | 01:35 PM
crossf-150's Avatar
crossf-150
I have a 1991 xlt texas lariat extended cab f-150 and I took it to ford today for a oil change and they told me that my throttle body and injectors are getting Black and Gummie. How do they go about cleaning them? Do they remove them or do they hook a machine up to them ?
Old Jan 31, 2004 | 08:32 PM
LxMan1's Avatar
LxMan1
How do they know that your injectors are black and gummy? You can't tell without removing them. I'd doubt that they did that during an oil change!!
Old Feb 2, 2004 | 09:19 PM
crossf-150's Avatar
crossf-150
Good point! I didnt even think of that. is there anyway that the throttle body could have been seen or is that something that takes alot to get at?
Old Feb 3, 2004 | 10:29 PM
LxMan1's Avatar
LxMan1
Just remove that big black air tube that runs from the air cleaner box and you can look right in it.
Just wipe it out with a clean rag and it should be fine.
Jimmy
Old Feb 4, 2004 | 03:43 AM
PW01's Avatar
PW01
And, as a preventative measure, run a bottle of Techron every 3000 miles!
Old Feb 4, 2004 | 11:59 AM
beartracks's Avatar
beartracks
There are intake tract spray cleaners available. It won't help the injectors but you need to keep the throttle blade and idle bypass passages clean.
