Towing Capacity
Old Jan 31, 2004 | 01:37 AM
Highway Hoedown's Avatar
Highway Hoedown
Towing Capacity
I currently have a 1978 F250 Camper Special 4x2wd 460/C-6 with a 4.10 possi and 33in over size tires.
I'm wondering how much my towing capacity would be reduced or changed if I replaced the 4.10 with a 3.54?
Old Jan 31, 2004 | 02:11 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
I think about 1000# would be a close ballpark figure. With your oversized tires, your trucks effective axle ratio is closer to 3.75 actual ratio. A 3.54 axle would bring the effective ratio down to about 3.31. Ford usually recommends a minimum axle ratio of 3.54 for heavy duty towing.
Welcome to FTE and thanks for joining us in the Towing forum
Old Jan 31, 2004 | 12:40 PM
Highway Hoedown
I didn't realize just how much my over size tires effected the ratio....
Thanks horsepuller!
Old Feb 25, 2004 | 07:47 PM
carpe_diem's Avatar
carpe_diem
I wish I had 3.55 instead of 4.10. The latter is good for weights over 10,000 lbs, even 12,000 lbs. But 3.55 is better on highway and gets you better MPG with lower RPMs.
Old Mar 5, 2004 | 10:37 PM
Go Navy-Beat Army's Avatar
Go Navy-Beat Army
New Gears
I just changed my gears from 3.55 to 4.10's. Unloaded mpg went from 18 to 15. Haven't tried loaded yet but if I was concerned about fuel milage I'ld get a Honda.
Old Mar 6, 2004 | 12:24 AM
Highway Hoedown
After spending some time pondering the whole thing: I may change out the rear gear to a 3.54. but the truck was designed to pull, and that is ultimately what I would like it to do. My answer for better gas milage is: I'm getting a second truck that will give me the economical up-side and pretty much leave my tractor truck as the hog it was meant to be.....
daddylee100
All Things Towing
Jun 17, 2013 05:48 PM
fordman400
May 6, 2010 08:40 AM
drthay
Mar 18, 2005 12:46 AM
alexisdakota
Jan 26, 2005 07:45 PM
kewpalace
1983 - 2012 Ranger & B-Series
May 2, 2003 01:37 PM
