Tire size VS/ MPG
Old Jan 30, 2004 | 11:23 PM
aquaholic's Avatar
aquaholic
Tire size VS/ MPG
We talked about this a little in another thread, thought I would test the waters. I have a '00 F250 4x4 long bed super crew. I changed from the factory tires to a 305/70r16. I know this changes my final gear ratio, but the truck looks sooooo much better with this size tire than with stock--------------
Problem is, MILAGE SUCKS!!!!!! I instantly went from getting 300 miles per half a tank to getting 190 to 200 miles. (18 ~18.5 to 12 ~ 13)
Question is this: Other than the obvious (back to stock tires or change gear ratio front and rear) are there any tricks?
I am running the new programmer ( 3 settings) and a flat K&N (I know, it will be changed shortly-used 'em in gas motors for years, have been picked on enough now!)
Old Jan 30, 2004 | 11:39 PM
bender97f250's Avatar
bender97f250
You basically answered your own question,my only other suggestion would be to try and keep your rpms under 2000. BTY, having the K&N is not a bad thing IMOP.
Old Jan 31, 2004 | 04:21 AM
Quadzilla's Avatar
Quadzilla
One thing you might have thought of, but didn't mention, is that your speedometer/odometer might be off quite a bit as a result of the change. When I bought my truck, the previous owner had just installed 35" tires, but hadn't done anything about recalibrating the speedo. After a short time, I realized that I was actually travelling quite a bit faster than the speedo indicated, so I recalibrated it. Without changing anything else at the time, my mileage went up about 8%. Of course, my mileage didn't actually change, but my ability to measure it did.
Unfortunately, I don't know what the procedure is for recalibrating the speelo on a Super Dury. I do know what to do if you drive a pre '99.
dukie1877
Jul 24, 2011 03:11 PM
WTHAYNES
Large Truck
Jul 19, 2011 09:24 AM
50jd60
Aug 30, 2004 03:19 PM
14u2nv
Modular V10 (6.8l)
Mar 4, 2004 04:26 AM
CJay
Mar 16, 2000 05:38 PM
