Engine Roar
Old Jan 30, 2004 | 08:55 PM
fordborn's Avatar
fordborn
Engine Roar
Lately my 5.4 has started to roar at around 2000rpm. Maybe roar isn't the best description it soulds more like the soud you used to get when you opened up a big 4-bbl carb. It didn't used to do this though. Any ideas?
Old Jan 31, 2004 | 10:29 AM
Brian_Puff's Avatar
Brian_Puff
have you changed anything with the intake?
Old Jan 31, 2004 | 11:10 AM
fordborn's Avatar
fordborn
running a K&N in the intake, it was serviced about 4000 miles ago. Thanks, for asking it might need serviced again, i'll check it.
Old Jan 31, 2004 | 11:18 AM
Brian_Puff's Avatar
Brian_Puff
i wouldnt say that has anything to do with being serviced or not, but maybe your just hearing the intake. i woulndt think only a k&n would bring out this noise that much. does it do it at crusin speeds? or jsut when you punch it?
Old Jan 31, 2004 | 01:53 PM
cocot's Avatar
cocot
A bad clutch fan will produce a roar sound.
Old Jan 31, 2004 | 02:49 PM
fordborn's Avatar
fordborn
does it at a steady 2000rpm. I can hear the same type of sound when I put my foot in it but at a steady speeed it is only at 2000
Old Feb 1, 2004 | 11:33 PM
FortyFords's Avatar
FortyFords
Chk the clutch fan ,by seeing if it will spin with a little resistance when engine is shut off.
If it moves with alot of force then its bad.
Rich
