Are dual gauge A pillars paintable. Or better yet can you buy them already in the interior color (mine is gray). I'd like the factory look. Thinking of putting a trans temp gauge and am WIDE OPEN to suggestions for the other gauge. ( If they made single gauge A pillars, I would buy that)
I believe they all come in black, at least my auto meter did.
You can buy aresol interior paint usually at a good paint shop, to match your interior. I went with trany temp and oil pressure, never trusted the factory oil pressure gauges.
They do. Go to Diesel Injestion Service.
Check out the cool replacement for the stock gauge-cluster panel that will hold two gauges. Very cool!
If I were going with just two...(I may)...then I would choose tranny temp and voltage. But since I can't decide...when I do finally do my guages I'll more than likely go with 3 and add the Oil Pressure.
